Use more than one non-PS4 controller with Remote Play
  • Use more than one non-PS4 controller with Remote Play
    Hi everyone,
    First, great application! My dualshock started having quite a lot of issues, and being able to use my xbox one controller is bless.
    That got me thinking and trying to also connect Joycons (L+R) to use them as a second controller.
    Is this possible? So far after trying around and watching videos I have managed to use either the joycons or the xbox controller as Player 1 but not both as Player 1 and Player 2.
    Thank you in advance!
    Hi there,
    I think it's a remote play restriction. The console needs a new user for each connected controller, and the remove play is connected to a single controller. reWASD allows creating as many virtual DS4 controllers as many devices are connected, but PS remote play recognizes the only a single device.
      Hi Star-Lord,
      I see! Ok, there is not much that I can do about that then. Thanks for the reply. It´s a pity, I bet that the possibility is there but sony doesn´t want to allow people to use it.
      Thanks again
