Hello, I have a problem and although if I activate the fortnite aim assist and double movement config, the aim assist only works after 4 seconds. I have rewasd the 16.99 package so paid license for everything knows who knows what is the cause of the double movement is immediately bare aim assist only works after 4 seconds. i am btw german so you can also write german
Fortnite Aim assist delay
I'm afraid there's nothing we can fix there. Though you can try these out:- check in-game settings that might be related to this problem;
- check if you have any unwanted [Shift modifiers] set (can be seen on main [Shift] at [Keyboard] sub-config);
- try disabling [Slots] change shortcuts at [Preferences > Slots]
- if you're using [Autodetect], check if no other process comes on top (some overlay maybe?), or disable [Autodetect] and apply config manually.
