Dualsense not turning off when inactive, running out of battery
  • Dualsense not turning off when inactive, running out of battery
    For some reason my Dualsense isn't sleeping anymore, it just runs out of battery, even when not being used actively. Eventually my PC goes to sleep and then the controller sleeps, but rewasd isn't letting it sleep for some reason.
    Do you have the [Turn wireless gamepad off if it is not active during X minutes with applied config] option enabled at [Preferences > Gamepad]?
      I do, yes.
        As far as I understand, the controller goes to sleep as it should while reWASD is off, is it not?
          To be hones it's hard for me to tell as I only use the Dualsense with rewasd, and I have rewasd running automatically.
            Just checked and I didn't have the latest firmware for my dualsense, will check just in case that makes any difference.
