Today, we have released a new major version — reWASD 5.6.2 — that includes several new perks and many important fixes. We hope you won’t hesitate to update
- Choose the angle of axes for sticks and trackpads
- Increase the sensitivity of the mouse mapped to the physical stick
- Check improved Gyro transition from Nintendo controllers to Virtual DS4
- Use the latest version with several important stability improvements
- Fixed: Controllers are not detected in reWASD after the Xbox Extended Feature Support option is enabled and disabled in Big Picture
- Fixed: reWASD service crashes if Remap is turned on and off rapidly several times with Azeron keypad
- Fixed: DualSense LED settings are not applied automatically after enabling the previously applied config if the controller was connected wirelessly and was turned off using a command or the correspondent reWASD setting
- Fixed: Virtual keyboard rate doesn’t influence keyboard combos and keyboard mappings set to Toggle or Turbo
- Fixed: GUI crashes while trying to filter an empty list of additional mouse buttons
- Fixed: The config with an unmapped mouse that doesn’t have a shift that frees it is not applied if the user has canceled the confirmation and checked Remember my choice with the similar config
- Fixed: Combo that includes a trigger and several stick moves and is set to Turbo may lock the stick after a few iterations
- Fixed: GUI crashes while trying to add a new adapter with MAC-address that includes -
- Fixed: The list of associated apps is empty for the imported config until the GUI restart
