Meet our small but mighty release which, we hope, will make your gaming experience even better. Let me show you the details
The list of fixes is below:
- Enable and adjust Trackball mode for Steam controller
- Manage configs applied to Slots when Remap is OFF and get back to the same Slot after turning Remap ON again
- Change the Size of any Overlay type
- Hook gamepad and keyboard controls in Shortcuts
- Enable Microphone LED of DualSense on Remap and Shift changing
- Change the type of the virtual controller or remove all its mappings using Magic Wand
- Copy all stick and gyro settings to use in new configs or layers
- Check Total combo time while creating complex combos
- Fixed: It is not possible to hook SR/SL buttons on Joy-Cons in reWASD GUI
- Fixed: Toggle of the analog trigger set to Long Press activator toggles trigger even with a slight press
- Fixed: Any mapping in a Shift layer won’t be triggered automatically without the necessity to re-press the button manually if the layer was switched while this button is pressed
- Fixed: The gamepad button used as Hold Shift Jump won’t work natively if the gamepad is remapped to the virtual controller automatically and the manual mapping is not set
- Fixed: The LED of Xbox Elite 2 & Xbox Series X doesn’t react on the Low battery status
- Fixed: Not all strings are translated on the fly — restart is required after changing language
