Issue with PS Remote play connection with reWASD
  • Issue with PS Remote play connection with reWASD
    Hello everyone. reWASD on the line 🙌
    👉 We want to address an issue that some of you might have encountered while using reWASD and PS Remote play. We are aware that since the last update of PS Remote play, it no longer works with virtual DS4 gamepads 🥺🥺 We understand that this is a significant problem for many of you, and we want to assure you that we are working on a solution. We want to apologize for any inconvenience this may have caused, and we want to thank you for your patience and understanding.
    We are doing our best to solve this issue as soon as possible, and we will keep you updated on our progress. Thank you for your continued support.🤩🤩
    Sincerely, reWASD Team 😘​
    Click image for larger version  Name:	post-fb-Problem-with-PS-Remote-Play.png Views:	1 Size:	451.0 KB ID:	235925
    Hey again!
    While reWASD team is working on best solving the issue with PS Remote play connection, our user has found another way:
    reinstalling the older version of Remote Play solved the problem.
    Download it from here: https://drive.google.com/file/d/1_h9oyBAUykWM0KgUMLg-F9EVYQqoUviR/view?usp=share_link
    Then patch it with this: https://github.com/xeropresence/remo...ersion-patcher
    This will make the app think is updated so it won't bother you with the update message whenever you open it. Should work for future versions.
    The original post on Reddit is here
      Hey everyone!
      Let`s check new update of reWASD with fixed issue ➡ ➡➡https://forum.rewasd.com/forum/rewas...n-rewasd-6-5-1
        Originally Posted by iren.bratsun View Post
        Hey again!
        Thank bro.
