We’ve rolled out a small update focused on improved game compatibility and a minor Send Input fix.
What’s new:
Improved compatibility with certain games that previously conflicted with reWASD;
Affected games can now launch without uninstalling reWASD - just make sure the app is closed;
Fixed an issue where Send Input mappings could react to unintended input sources.
Quick tip:
If you’re launching a conflict-prone game, fully exit reWASD from the system tray before starting the game. This helps ensure a smooth launch while keeping reWASD installed and ready to go.
We’ve also updated the compatibility status of reWASD Basic. It’s been running smoothly and stably across all games and apps since version 1.0.1, so feel free to update. If you experience issues with automatic updates, simply download the latest build from the official website:
We’re continuously monitoring compatibility changes and working to keep reWASD reliable and flexible for every setup. Thanks for sticking with us - and keep the feedback coming!​
What’s new:
Quick tip:
