Hi.
I wanna a Feature, if a specific device connect, auto enbale remap for the driver's default config.(or last activate config)
I use same config for a lot Applications, and havent Associated to any Executable file.
Every time i do need enable the config manually.
That is fine, for once, but sometime during the play, driver will disconnect(unexpected)...
Then i need to Switch to REwasd manually and activate it.
In this time is a little bit bother if i can't each mouse/Keyboard easily..
If i don't need to got the mouse, it will be more comfortable.
