50 % of analog stick to paddle
  • 50 % of analog stick to paddle
    I have an xbox one elite.
    I found that it is possible to make a paddle to behave like the right stick up for instance. The problem is that it gives 100 % of the stick and i want a percentage of it, let say 50 % for instance.
    I found in this post (https://forum.rewasd.com/forum/rewas...nd-not-as-keys) that it is possible with rewasd 5.2 which I have (or i didn't understand this post correctly).
    But I didn't find how to do it.
    So :
    How do I make a paddle to simulate 50 % up of an analog stick ?
    Thanks
    Thank you for the report.
    The best option for you is to set virtual stick mapping and do max deflection adjustments. Let me show what I mean -
    [link expired]​. As you see I've set the up\down stick to digit buttons and set max deflection approx. on a half. Now my virtual stick deflects 50% of the full range. You may map the same way with paddles.
