As the title states... ability to unmap LALT and LCTRL since we have Ralt and Rctrl for system funcitons. This will not alter ctrl alt del function and will give us ability to use these common fps buttons in our setups on keyboard.
Ability to unmap LALT and LCTRL since we have Ralt and Rctrl for system funcitons
Thank you for your suggestion.
reWASD does not unmap Some functional control keys of the keyboard, so you can always get back to the normal keyboard using Ctrl+Alt+Del (it will switch the remap off) and will be able to navigate Windows. Just a precaution to be sure you do not lose the ability to control your system.
