I don't know if this was a design choice, but each new profile I create includes a Gamepad config with all the bindings from the Desktop profile you guys provided. Because of this, I'd have to clear each binding one by one, or create a new config and delete the first one as a workaround. There is currently no way to easily clear all the bindings in one go and I do need this for the gamepad especially when using the Magic Wand does no clear out the entire Gamepad config when mapping a virtual gamepad.
I would like this as a function for keyboards and mice as well.
Maybe you are cloning the config instead of creating it? Also, we do not add Desktop config to our app by default during a few latest releases, so I would suggest you to start from checking the updates. The up-to-date reWASD version is 5.5.1. You can check the updates from Preferences (the gear icon at the bottom right), General tab.
