Add more analog stick features to Key Combo
  • Add more analog stick features to Key Combo
    It would be great if there were more analog stick movements in Key Combo.
    I'm playing God of War Ghost of Sparta and the buttons to dodge are L1 + R1 + Left stick. My idea was to map the dodge to the right analog stick, like it is in the main games, but in the Key Combo menu I only find these options. Click image for larger version
ID:	221941 So, I can't map the dodge to a specific direction on the right analog stick.
    Other thing I would like is being able to record analog stick movements in Key Combo.
    There's one QTE in the same GOW game where I have to rotate the stick constantly as fast as possible and because of my disability, I can't do these fast analog sticks QTEs. My idea was to record and map that rotation to a single button and then just click on it repeatedly, but apparently that's not possible.
    The stick recording will be added next software version. But if you need the diagonal movements in the combo you ma add it in a manual way. Check this use case link
