I've noticed that under vibrations, there is currently an option to remap the left/right trigger vibration to the left/right main. Would it be possible to map these Impulse Triggers (xbox) to activate Adaptive Triggers (PS5), potentially using output that is similar to the 'vibration' setting under the Adaptive Settings for the PS5 controller?
Mapping Impulse Triggers to Adaptive Triggers
Is it possible to create some general vibration pattern which is similar to impulse triggers vibration and use it later for DualSense's triggers in Xbox One emulation mode? Skipping every special functions, just leaving time frequency - impulse trigger for Xbox One had to work for 2 seconds, so general vibration pattern on DualSense will vibrate for 2 seconds too. Doesn't matter if vibration is strong or light.
In this way we would be able to receive basic support for Impulse Triggers on DualSense and emulation will be more useful. They are different technologies, but vibration time should be something what both controllers are sharing.
Similar thing can be in the future for Xbox controllers. When DualSense adaptive trigger have to vibrate, then basic impulse trigger vibration can be activated on Xbox controller. It will be not accurate, but can share similar features between controllers. I'm not sure if it is possible, but would be cool. Especially that Xbox One controller emulation is already implemented
