Dear ReWASD staff,
I would like to kindly request the ability to have a range for the pauses in the key combo feature, right now it's straight forward, you put an amount of milliseconds and that's it, what I would like is being able to put a range instead, so instead of a straight forward number, for example 100 ms, I'd like to put a range, say 100 - 150 in the option, if you want to be even more generous and take it a step further, include a percentage for said range, as in 20% it'll be 100ms and 80% it'll be 150 and so on, but that's just extra, just adding a range is more than enough.
Regards,
Yami.
Regards,
Yami.
