Add function of mouse cursor lock.
  • Add function of mouse cursor lock.
    When using the virtual stick on mouse, the cursor will slide on the display screen, this problem will seriously hinder game play. If REWASD can lock mouse cursor to a designated position, this problem will be solved.
    Hello! Use Mute on the mouse, this will block native input.
    To do this, you need the Advanced mapping feature.
