Hi, I tested reWASD some time ago, and didn't find it suitable for my use-case.
Unfortunately the tool did still know this. Perhaps you could reset the trial phase after several month? If this is bulletproof I think this shouldn't cut your sales.
But I have an actual use-case: The Diable4-Beta. Therefore, I just brought the software (and of course the full package ;-)) just to try it again.
I tried to configure my Azeron (classic) as Gamepad, but also want to use the mouse for some stuff (inventary and so on).
I would suggest these improvements:
- Copy multiple (its great there is a copy feature at! but I think it is still improvable!)
- Cut (usually I used the copy-feature to move assignments. A cut- (or move-)feature would reduce this by one step)
- Drag'n'Drop (same idea as above, make it easier to move assignments)
- Pre-configured commands and drag it in (as reference! changes in pre-configured list are updated on the keys. Useful if a command is used identical on different buttons or devices)
- Switch layer by joystick (zone) (But I have read it's already planned and in my use-case I found it wasn't necessary at all (but just because D4 is great with a controller))
- Undo/Redo​ (or have I missed it?)
Next suggestions are a little bit more advanced and more focused on replacing Joystick-Gremlin for Flightsim-Configuration
- Plugins (e.g. joystick gremlin uses python-scripts)
- Own devices (so we can use it for HOTAS, HOSAS, ...)
After some finetuning I'm pleased with my config. Unfortunately I will not use it until June again ;-)
Best regards
Best regards
