Battery percentage and ability to turn off gamepad
  • Battery percentage and ability to turn off gamepad
    I would like to suggest a few features that are sorely missing in this great reWASD app.
    • Display battery percentage when you hover over battery tray icon.
    • Option to turn off gamepad from context menu by right-click on battery tray icon.​
    It already works that way:
    Could you specify - a virtual one or a physical one?
    Also, you can use these mappings:
      Doesn't show battery percentage. Xbox Series X Controller connected via wireless adapter.
        Are you using a Bluetooth adapter or an official Xbox WiFi one?
          Offical Xbox Wireless Adapter was included with controller. I need this to control an LED.
            Xbox controllers do not report battery in percents, so it is not possible.
              This app https://github.com/NiyaShy/XB1Contro...tteryIndicator can report battery status (high/medium/low) would be nice to have same battery status by hover over battery tray icon.
                The icon itself already shows that. Or the text tooltip is absolutely necessary?
                  I didn't notice this, but if the icon shows it, that's enough.
