Suggestion for a Logitech Racing Wheel G HUB G920
At the moment, our app doesn't support anywheels, but we do plan to make them work in the future releases.
If the device has X-Input mode, reWASD should be able to detect it as an Xbox gamepad — so you can adjust at least the main controls. Hope it could be a temporary solution.
While we are working on it, please check our list of the supported controllers — you may want to use reWASD with other devices.​
