I've noticed that most games don't like the default setting of 10ms, I always need to set it to 20. Is it possible to change the default value to 20ms, even through a config file or something? I remember it was possible in Xpadder, would be a nice QoL feature.
Setting the default value for "delay between keys"
I know how to set it but it always defaults to 10 for new profiles and mappings, I would like to change the DEFAULT value so I don't have to change it for every button on new profiles.Originally Posted by strokel View PostHi. If you mean the delay between the buttons in a combo, you can change it by entering the desired value in the corresponding settings field.
If you mean the delay between standard mappings, then it cannot be changed.​
Ok, thanks. It's not *that* important obviously but it would be convenient, and seems easy to implement. Just a small QoL feature to make reWASD even better.Originally Posted by strokel View PostUnfortunately, reWASD does not have this feature. This may change in the future, but I can't promise anything at this time.
