Technical questions regarding turbo, delays, pauses, and a few other features
  • Technical questions regarding turbo, delays, pauses, and a few other features
    Hello, I have recently purchased the full version of reWASD and still have some questions after researching the guides and forums. I will try to be as detailed as necessary.
    1. What is the difference between the "Delay between keys" option versus the "Add pause" option? Is "Add pause" option just a more customizable version of adding "Delay between keys"?
    2. Is there a way to randomize the delay or pauses between keys in a macro? Or, can you randomize the time intervals with the "Turbo" option?
    3. Will there be a pause between iterations if the macro ends with a pause from the "Add a pause" option, while the "Pause between iterations" value is at "0"?
    1. Basically, it's the same option that has similar functions. Delay between keys works after each up\down (like up - pause\down-pause) if you set the value (ms). "Add pause" works the same but you may drag&drop pause between any up\down.
    2. There are no options to randomize pauses for now, but this is a great idea and we definitely take into the account.
    3. Yes, it will be pause and macro ends with the value you set in the "Add pause" option.
