GTAV/XBoxOne Controller Question
  • GTAV/XBoxOne Controller Question
    I've got a question! I'm using ReWASD for Grand Theft Auto 5, and while I'm able to remap the XBox One controller inputs, the game is performing both the default and custom action of the controller. Is there any way to make just the custom actions be recognized?!
    Seems that you need to add Unmap to all your buttons. You may found "Unmap" button in each mapping frame. It switches the native behavior off.
    If it won't help, could you please specify which actions do you map? Do you use keyboard keys or controller buttons?
