Rewasd broken?
  • Rewasd broken?
    I was wondering if I could get some help with this. Not sure what has gone wrong. Has happened today with apparently no prior interaction. I updated Windows 10 3 days ago but it has worked since. I have tried to re-download it but I cannot find where without having to buy it again?
    Any help would be much appreciated.
    Cheers,
    JoshClick image for larger version
Name:	2019-08-01 19_05_58-SS.jpg
    This happens after massive Windows 10 updates. Not sure why it was working right after the update, maybe Windows got some hidden patches later. I'm sorry for the inconvenience, and you may be sure that everything will work after you re-install reWASD.
    You can download the latest version from https://www.rewasd.com/
    Just click Download button, no additional payments required. We have the same build for the trial and paid version, and in 99% of cases it will be installed without the necessity to activate your license. If somehow the previous activation is broken and you will get a message that you need to Buy a license, pay attention to the buttons on this message. You will "Activate". Click it, enter your serial and here you go.
    If you will get a message that the license is already used on another PC (previous Windows version), click "Revoke" link to free the previous activation.
    You serial number is safe at your personal account (https://www.daemon-tools.cc/account). The email used for the purchase is your login. You can restore the password following the relevant link or you may contact me directly here, and I will reset it from our side.
