Rewasd has been recognizing the up key as the down key, pretty simple problem. The down key is also the down key, so i didnt do anything wrong. This problem started today, as yesterday it was working just fine.
"How do you know this is a problem with Rewasd and not anything else?"
Other softwares have been telling me that both up and down are the same key. Also, when i go to use Steam's Switch Pro Controller support (with rewasd off), it works just fine.
