reWASD wont open after update!?!
  • reWASD wont open after update!?!
    Hello hoping someone can shed some light on this issue, couple questions, any help would be greatly appreciated. Keep getting the pop up shown in the pic I attached. It wont let me access the program, just keeps telling me to reinstall an then exists.
    1.) How do I fix this without Losing all my Configurations!?!
    2.) Will I lose my Configs if i reinstall?
    3.) Do I have to re-buy the program again if i reinstall?
    1. Please re-install the reWASD from the scratch. Remove the software from your PC, reboot it and install again. It fixes the problem for sure. You won't lose configs as they store different directory - C:\Users\Public\Documents\reWASD\Profiles.
    2. No need to re-buy the license again. The license links to the system ID after software activation buy revokes after software removal. The revoked license is ready to use again, no extras.
