Hi. I installed reWASD for the first time. After every reboot it keeps telling me to reboot my computer. I also cannot uninstall it since it just tells me again to reboot my PC. -_- How can I uninstall it now o try again?
Cannot start or uninstall reWASD
Please launch registry (Win+R - regedit) app as Administrator. Just type it in taskbar search box to open.
Here, you will need to go to 3 directories:
1. HKEY_LOCAL_MACHINE\\SOFTWARE\\WOW6432Node\\Disc Soft\\reWASD\\
2. HKEY_LOCAL_MACHINE\\SOFTWARE\\Disc Soft\\reWASD\\
3. HKEY_CURRENT_USER\\Software\\Disc Soft\\reWASD\\Config\\
Two first ones may include "RebootFlag" item. If yes, please delete it.
The third directory may include "RebootRequired" item. It should be removed too.
After you find the needed flags and remove them, please try to launch the app again.Don't worry! Be Happy!
