Key Combos
  • Key Combos
    Is there a reason I cannot bypass the Key Combo may be cheating prompt? I am trying to set up a controller for ArcheAge Unchained, but would like to map the keyboard keys 1-0 (excluding 8 and 9 for potions) to D-Pad (UP=1, Left=2, Down=3, Right=4, LB+UP=5, LB+Left=6, LB+Down=7, LB+Right=0) using an Xbox One controller. This is also very useful in games where it's not competitive at all, but there are a ton of button options. The layout should be similar to something like Fable from Xbox. Why have a Key Combo option if it can't be used? I paid thirty bucks for a partially available program.
    You do not need Combo, you will need to add mappings in Shift 0 and Shift 1.
    First, choose each D-Pad button and map it to the needed action, using reWASD mapping list:
    Click image for larger version  Name:	968c4fce44.jpg Views:	0 Size:	102.0 KB ID:	217405
    Then, go to Shift 1 (1), choose LB (2), check "Use as Shift modifier" option (3) and set other four mappings for the D-Pad (4):
    Then press Apply.
      Welp. That makes me feel like an idiot and I greatly appreciate it! LOL I was working on this for about three hours before I gave up. Seemingly, I had an issue where when applying the combo, it would stay in the system. I rebooted tonight, and its working (the saving, not the functionality), so I'll take your recommendation instead.
      THANK YOU!
        You are welcome!
        Hope it will be the last misunderstanding with reWASD :satisfied:
