Hi guys
First I would like to say that you come a long way with your software what can do and how easy is to use. Love the features but will be nice if you have updated tutorials on your website. I didn’t know that this forum existed and manual is poor. To the point. Two days ago for the first time your software crashed and didn’t open anymore. The was a message that reinstall again. I did and since then I noticed that there is problem with controller. First my Elite Dangerous setting stopped working and only responded to fully customized controller in rewasd. Secondly trigger LT keep pressing itself. I’m aware of the issue with elite controller so I assumed is broken. The thing is that it only work that way with rewasd being enabled (remap on) I tested online the controller and on Xbox app win10. There is more, for some reason it keep disconnecting self but at the same time Xbox app testing mode working perfectly.
is that update? Do you know what happening? Can I install previous version (do you have link)?
just couple more questions what are slot for? Can you send me link to topic on this forum if that easier? How you can use profiles from website, let say I downloaded elite profile but in game those mapping doesn’t match so what is the point?
Please help
Please help
