Problems with automatic reWASD activation upon entry into the system
  • Problems with automatic reWASD activation upon entry into the system
    I want reWASD to use the Tray Agent.
    But once in the system, I didn't want reWASD to start automatically.
    What should I do?
    If you don't want running reWASD automatically, then you may disable it in the Task Manager, like this. In this case, the Tray Agent launches only when you open it manually.
      Thank you very much!
        You're welcome.
