I'm sure I am making a silly mistake but I've had a look around and I can't find what I'm doing wrong.
I have an xbox elite controller on which I only want to remap the four paddles (for now), to A,D,I,K on the keyboard. I want to use the rest of the pad as usual xbox inputs.
I have unmapped them all from gamepad inputs and mapped them to what I want and sometimes it works but other times it remaps them to random keys (strangely enough, usually the D keyboard key), also it will often map various points on the right stick, also usually to the D keyboard key and sometimes it'll do it to one of the triggers too...
I have unmapped all that I can, I press save or apply, it seems to save but then i'll go back and there will be random mappings all over the place.
Please help !
Thank you,
maltloaf
Please help !
Thank you,
maltloaf
