Is there any way to combine x1 controller and mouse, but retain mouse control and accuarcy? As in, not have to remap mouse movement to right stick?
Simple question...
Most games do not work with two inputs flawlessly, so when you use controller and mouse, the game switches from one input to another that may cause some lags. Not all games work this way, so it is highly depends on the one you need.
If the game does have this problem, the best way is to switch your controller to keyboard and mouse mappings — unmap each and every control and set the relevant KB&M actions. You may try searching for such configs in our Community so you won't need to create it from scratch.
