Release button combo
  • Release button combo
    Hi, is it possible to set a combo on the release of a button? I can only see the option to map another button to be pressed on release.
    What I'm looking to do is:
    Press and hold square (ds4) manually.
    on release of square, wait a set amount of time, then tap square again.
    The amount of time I hold square at tge start will vary, so I cant just remap it all. If the release trigger had the option to run a combo I would be able to do this easily
    Start Press\Release doesn't have a combo option to make but it will be added next reWASD versions. Rest of activators, like single, double, triple, long presses do have combo ad perhaps it could be an alternative.
