One PC
  • One PC
    Just wondering what the "1 PC" thing means when purchasing reWASD. I have a laptop & a desktop and want to use the program on both. Would I be limited to only using it on one computer permanently due to the 1 PC thing?
    Basically: Does the one pc thing refer to simultaneous use or unique device use (i.e can only use it on my laptop and only my laptop forever).
    It means that the license allows activating the software on 1 PC, bot on 2 PCs for simultaneously usage. Of course, it doesn't mean that once installed you gonna use the reWASD on specific PC forever. The license revokes in your account and may be used on any Windows device again. The revoke is free and no limits.
