So I've been using reWASD with xbox for a while, but since we have access to keyboard mapping too, I started using my keyboard. I was wondering if there is a way to bind a hotkey to switch between keyboard profiles, or to bind a hotkey to set reWASD on and off, so I can type in chat without executing any mapped combos. Thanks for answering!
Switching Profiles with a hotkey?
This topic is closed.
Sure you may set any keyboard combination to switch slots. Go to General - Slots and bind any keyboard buttons (2 or more unique buttons). More detailed regarding Slots here - https://help.rewasd.com/preferences/slots.html.
The ctrl+alt+del turns remap off completely - https://help.rewasd.com/basic-functi...-features.htmlDon't worry! Be Happy!
Thanks for your reply
Also, you may check Autodetect. That is not exactly the one you asked, but may be helpful. With Autodetect, you can adjust which config is applied when the certain app is in focus. After you leave this app, the remap may be switched off.
