Having Difficulty Using Joy Con.
  • Having Difficulty Using Joy Con.
    I'm try to use a joy con and mouse but. after I've I connected the joy con and bind my buttons I get this weird bug where Remap turns on and off rapidly. My joy con then seems to disconnect from reWASD and I can no longer select it again until I disconnect it and reconnect it through Bluetooth. I've used an Xbox controller and it works fine but I can't seem to get the joy con to work properly. Any help is appreciated.
    Please check that you don't change slots accidentally pressing slot changing combinations. To prevent this in further usage, you can disable all the slots if you don’t use them.
    Do you use the autodetect feature?
