I have a binding on both Single Press and Double Press on my Left Trigger. The Single Press works perfectly. As soon as I engage the Double Press though, it seems to permanently take over as the only binding. From then on both the Single and the Double Press active the binding on the Double Press. It's almost like it's getting stuck in the Double Press state. If I go back into reWASD and remove the Double Press and then re-bind it then the Single Press binding works again, but only until I activate the Double Press and then it gets stuck again.
Double Press Issue on Left Trigger
