Hello. I bought rewasd. I have an XBOX gamepad, I need to emulate Dualshock 4 for PSNOW. When the remap turns on, both sticks have a significant dead zone near the 0 mark. Often vibration doesn't stop and it vibrates again. It is rare that sticks are defined as inverted on the left and on the right stick, the top is the bottom, and the bottom is the top.
Sticks have a dead zone, vibration doesn't stop, sticks are inverted.
Thank you for your report.
There is a setting where you may increase dead zone ti make the stick less sensitive. More details here - https://help.rewasd.com/basic-functi...ger-zones.html.
Please, specify about vibration? Are you talking about reWASD rumble that sets for digital buttons or game vibration? And the behavior with stick swapping is weird.
May I ask you to share your config file? What games do you try to play? Do reported problems reproduce out of the game (like https://html5gamepad.com/ online tester or joy.cpl)?
Hello, thank you for the help with the dead zones all is perfect!!!!
I'm talking about game vibration. When I jump in game and land, the gamepad vibrates slightly, sometimes it starts and does not stop until I jump again and land a couple of times.
What config file do you need?
The game is Hprizon Zero Down and Rocket league on PS NOW.
In the attachment logs made by rewasd during incorrect vibration and axis changes.Attached Files
Thanks for the logs. Could you please share a bit more information about your gamepad? Is it an official Xbox controller? What model is it? How do you connect it — wired or wireless?
We will try to reproduce the issue from our side to see why it happens.
Have you noticed only one game with rumble issue or does it happen with any game and reWASD?
As for the config Star-Lord asked, it is the configuration with reWASD settings. Please go to this folder: C:\Users\Public\Documents\reWASD\Profiles
There, find the folder with game name, open it and send me the *.rewasd file you will see there.
Gamepad is wired. Model MSI GC-20, it has hardware emulation XBOX gamepad
There are few games that normally accept a DS4 gamepad. In all PS Now games, vibration does not stop. I tried to start MadMax and FarCry 4 there is no vibration in them when emulating DS4.
I use a standard profile "PS4 remote play" Perofiles in attachments.Attached Files
Thank you for the logs and profile. The profile is standard indeed. The logs contain extremely small pieces of information to conclude the problem causer. I think the problem relates either controller (exact the MSI GC-20) or the PNow service itself.
1. Please check if the problem reproduces with https://html5gamepad.com/ service. Plugin controller and emulate the DS4 virtual one. Open the provided link and press test vibration. The rumble should start and stop automatically. Check your behavior. Would the vibration stop or keep triggering?
2. Do you have some games installed on your PC? Please check it without PSNow. Plug the controller, create a virtual one and run the game installed on the PC. Try to reproduce the reported problem as well.
Let us know any results.Don't worry! Be Happy!
Hello! It looks like a controller.
In the vibration test on html5gamepad.com it also does not stop.
1 click on the test - normal vibration
2 click test - normal vibration
3 click test - vibration does not stop
4 click test - vibration does not stop
5 click test - vibration does not stop
6 click test - vibration stopped
logs in the attachment
Thank you for your report. Now we know the real problem causer. Unfortunately, reWASD doesn't support this particular device officially so, we can't explain why the rumble behaves like this. Perhaps it possible to update the firmware or contact the official MSI support team to request some details.Don't worry! Be Happy!
Hi there,
Happy to inform you that the gyro feature has been released. Please, update your current version to the latest 5.3 (Preferences - Check for updates).
This is a detailed tutorial - https://help.rewasd.com/how-to-remap/controller.html.
Besides the gyro feature new other features, bug fixes and improvements you may see this topic.Don't worry! Be Happy!
Updated, tried.
Everything works fine! Еhanks for your work. I use the gyroscope as the right stick for now.
In the “until down†game, the gyro is used to control the character.
Is it planned to redirect gyro motion of a physical gamepad to reWASD DS4 as gyro motion and not sticks WASD or mouse?
