rewasd don't stay in tray
This topic is closed.
  • rewasd don't stay in tray
    Hello , I just bought rewasd , and i have problem .
    I am using this for hyperspin . The problem is when i start hyperspin , rewasd open over hyperspin . So i need to minimize it , then it works .
    How to fix this issue ?
    thx
    Does the reWASD launch automatically when hyperspin is started?
    reWASD has a tray agent that works background and you may turn on\off remap using the tray only.
    Go to the Settings - Tray agent and checked "Use tray Agent" checkbox. Once the tray active it allows re-applying previously active config (on\off).
    Also, the tray agent allows enabling autoremap on startup - https://help.rewasd.com/preferences/tray-agent.html. Like, if you unplug the controller and remap was active or reboot the PC, etc., the remap becomes active automatically if you plug the controller again without the main menu.
    Do these options suitable for you?
      sorry for the late reply , its working . No worries
        Great, thank you for let us know.
