Hello there, I’ve been looking into purchasing rewasd for a while but have a question id like to ask before doing so. Is it possible to start a macro sequence with a multibutton hotkeys? What I’m trying to accomplish is creating multiple macro keys that require a double button hotkey. For example, on an Xbox One Controller I would press Select + A and it would play a macro I set, or Select + B and it would play another. The game I’m trying to get macros in requires that I have full functionality with default Xbox controls, so I can’t use a singular button as a hotkey. Is multiple button hotkeys possible with reWASD, or does the program only support singular button Macros support?
Questions on macro usage
Thank you for your report.
You may do it with Shortcut feature - https://help.rewasd.com/basic-functions/shortcuts.htm. So, you pick 2 or more buttons and assign the required key Combo - http://joxi.net/GrqX8GMS4dL3vA
Visit the online manual link to learn more details.Don't worry! Be Happy!
