How to temporary hold or toggle a KEY to disable rewasd or unmap?
  • How to temporary hold or toggle a KEY to disable rewasd or unmap?
    How to temporary hold or toggle a KEY to disable rewasd or unmap and use my mouse & keyboard?
    for example,
    I hold or toggle Lshift then I can use my mouse & keyboard
    Thank you for your question.
    There is no option to disable reWASD mappings unless to switch on an empty slot, like this - https://streamable.com/htkna. But if you have virtual controller mapping, the physical gamepad won't work switching, need to switch remap of manually. But, it will be fixed next 5.3. release (next week).
