razer problem
  • razer problem
    my friend just bought the full pakkage and he use razer blackwidow chroma v2 keyboard, razer mamba mouse and razer goliathus mousepad.
    but in rewasd app, rewasd thinks that the goliathus mousepad is the keyboard and the blackwidow keyboard is the mouse.
    mamba mouse works as a mouse but i can't get the blackwidow reconized as a keyboard
    sorry for my bad english
    Do you connect these devices with separate USB ports or using a USB hub?
    You may also do devices re-initialization, please check this video, describing how to do it - https://streamable.com/d29py.
      all on separate usb ports, i'll check that vid and see what i can do. thx
        Please, try to re-initialize devices and check if the problem persists.
