mapping keyboard keys to mouse axis - is it possible?
  • mapping keyboard keys to mouse axis - is it possible?
    I'm trying to configure my spinner for use in Tempest 4000. Since the game supports keyboard input, I wanted to assign buttons to the mouse axis. When I click on the mouse axis, I only get options to add joystick axis'. My group only consists of my mouse and keyboard.
    Is this not a supported pattern with rewasd?
    Thank you.
    Unfortunately, there is no possibility to map keyboard keys to the mouse axes in the current reWASD version, but this thing is in our to-do list.
    Is it a chance that this game supports controllers?
      Ah okay...the game does support controllers, but was having some issues. Perhaps steam was getting in the way...I'll play around some more and see what I can find out.
      Thank you!
        You're welcome.
          Thank you.
          I have a version of Tempest 4000 PC that will work with a spinner...
            Does this version support a gamepad too? Unlikely, that reWASD detects this spinner device.
