Joycons and Gamestreaming
  • Joycons and Gamestreaming
    I've got a curious issue when connecting Joycons to the Surface Pro tablet. After configuring them with Rewasd and playing games straight through Steam everything works perfectly. However when trying to play games anything but locally (Geforce Now, Stadia, Moonlight or Steam Remote Play) I lose left Joycon. Remote Steam shows 2 Xbox 360 controllers connected but games won't recognize these.
    I have no idea how I should tackle this so anyone got ideas?
    It may be a chance that those apps do not see the virtual controller.
    Please try to re-launch them (with Remap enabled), if it doesn't help, try to reboot your PC (with Remap enabled too).
    Here are a bit more detailed steps.
      Thanks for the tip!
      Unfortunately, it does not matter which settings I choose. Is there any way to make Windows see two Joycons as one single controller?
        Sure you can you may combine 2 Joycons parts as a single device. https://help.rewasd.com/how-to-remap...f-devices.html. The grouped device is detected as an Xbox or a DS4 virtual controller (depend on what controller to create did you choose).
