CoD Warzone: Mouse
  • CoD Warzone: Mouse
    Has anyone been able to get CoD: Warzone to work? The Keyboard remapping works, but the Mouse does not. I've got the advanced mapping to get the mouse mapped to the right stick and mapped the mouse clicks to the trigger buttons, but none of them work. Any suggestions?
    It may be a chance that the device initialization is not completed correctly. Please follow these steps:
    2. Use Detection mode to find the correct Keyboard and Mouse. If you press the keyboard button but see mouse in reWASD, then you will need to re-initialize it (from the context menu of an active device)
    3. After you are sure about all the devices, please group Mouse and Keyboard and try to Apply your config and test it in joy.cpl or in a game
      Ah that was it, it wasn't finding the correct input device ty!
        You are welcome!
