I made a post a few months ago, but at the time switched to a wired controller so I didn't know it was a lie. Even if I uncheck the led shift change the bar doesn't turn off. Please find a way to turn off the led bar. Or update the rewasd to work properly when trying to turn off the light bar. resets, task manager closing, turning the controller on and off ect. I've tried everything I can on my end. It would of been 10 steps less if I opened the controller and just taken out the led's... I know im complaining But I didn't purchase the program.
Still Can't Turn Off My PS4 led light bar.
We change LED (main, shift) only if remap if ON. Once the controller is plugged and remap is ON, it starts lighting up (not strobing, not color breathing, just keeps glowing) with yellow color or shift colors only when this option is checked.
Other color behaviors aren't related to reWASD.
Do you have any other mappers, like steam or else that also has LED options to set?Don't worry! Be Happy!
