I like to navigate my PC with my Elite controller but every time the controller turns off I need to get out my keyboard, bring up rewasd, select my controller, choose my profile, then apply and finally close rewasd. Is it possible to make my Elite controller the default device for controlling my PC so when I turn it on it just works and I don't need to do all the above?
How Do I Get My Controller To Always Navigate My PC
Thank you for your question.
Please, specify how do you connect the controller? I believe that you have Xbox Elite 2 connected wirelessly? What config do you the Desktop preset or made yourself?
When you close the reWASD, does the tray agent active (with this checked option)? And the version that you're using is 5.3, isn't it?
Anyway, we need more details that we ask you to provide.
Thank you in advance.Don't worry! Be Happy!
