The game I am playing needs to sprint by pushing arrow key twice(left or right). How is this done with mapping my xbox elite controller with using either the analog stick or dpad?
Xbox elite controller how to configure sprint
I think you may add such combo - https://prnt.sc/rtbmu1.
It's A button with 2 iterations that permits reproducing a button press\release twice. The same steps with "D".
Note, that you may set this combo for a double or triple press of the same control - https://help.rewasd.com/basic-functions/activators.html to leave the main mapping for the single press.
Please, let us know if it's helpful.Don't worry! Be Happy!
My question is can you make a combo and apply it to analog stick for controller? I do not have combo paid for so I want to make sure before I make that purchaseOriginally Posted by Star-Lord View PostHello,
Yes, you can apply a combo for controller sticks and digital buttons (D-pad). Please, select the required stick direction and pick the "key combo" tab. As far I understood your question you may do a combo adding iteration or adding A button twice in the combo editor - https://recordit.co/PdnBToOVOt.
The combo feature has 3 days trial so you may try to test it before the purchase. I also post the online guide about combo - https://help.rewasd.com/mapping-features/key-combo.htmlDon't worry! Be Happy!
Unfortunately I tried that and it does not work for this game because what I need is left arrow press / release and then left arrow press and hold in quick order to keep moving in that direction. This is a 2d side scroller argp type of game. Is that possible?Originally Posted by Star-Lord View PostHello,
Thank you for your reply.
You may add a pause between the second arrow press\release, like this. In this case, the combo triggers that way - https://recordit.co/4PJyJz1NMs. You need to select a more comfortable pause to play. So, move the stick to the direction and release it to reproduce the combo.Don't worry! Be Happy!
Unfortunately this does not work either. Now when I use this to go left my character will keep going left even though im changing direction because its still finishing the action. Hmm this shouldn't be to difficult I just don't know how to execute.Originally Posted by Star-Lord View PostHello,
I just want it to work like a normal directional pad. Just in this game you have to push left arrow once to walk and if you tap it twice you are now sprinting. How can I recreate this?
