How do I go about assigning a modifier button to Left trigger on controller? So I have normal layout and then when I hold left trigger my layout will change to the shift 1 layout. When Left trigger is not held down it goes back to original layout?
Assign shift modifier to Ltrigger controller
Thank you for your question.
The shift layout works when you press\hold the shift modifier (left trigger in your case). You can toggle the shift modifier https://prnt.sc/ruwdm9. In this case, shift modifier press\release (no need to hold) gives you shift layout, shift modifier press\release again gives you the main layout. Toggle Shift can be enabled while the Rapid Fire feature is purchased, or if it’s trial is enabled.
