Hello, I have a big problem because I switched from PS4 to PC and I can't play WASD. I was looking for a bit and I got here. I have pads from PS4 and Xbox One, I would like the left side to fall as it is and control the analog instead of WASD, right side I can assign it to the mouse. I tried to configure it, but none of it. It is a gaming laptop and detects: hid mouse, Logitech mouse and Pad. How to connect these devices at the beginning, or connect them? Do I have to enter the "Destkop" option to configure it later? It's about the game Rainbow Six: Siege downloaded from Uplay. Maybe someone can explain exactly what to do it. Regards.
PS4/Xbox Pad and Mouse on PC
Thank you for your question.
What do you mean by "pads from PS4 and Xbox One"? I believe it's a PS4 and Xbox controllers. If so, the left stick is for WASD, the right is for a mouse.
In this case, please plug your controller (if there are lots of connected devices use the Detection mode to be sure which of devices is), unmap the whole controller (use the magic wand (2)) and add some mappings https://prnt.sc/rw8cha. Hit the Apply.
With this configuration system detects keyboard inputs only (WASD and mouse). Is this behavior would you like to get?
BTW, check our community regarding required game configs - https://www.rewasd.com/community/gam...ege-controller.Don't worry! Be Happy!
