I have bound my switch pro controller to a DS4 to use with rpcs3, and it its shown by rpcs3 as a ps4 controller, but I am unable to bind the gyro on the pro-con to the gyro on the DS4. I have plenty of options to bind it to wasd, mouse, left, or right stick, but for some reason, not an option to bind it to the actual gyro axis. Is there a way to do this? Or, if not, could it be added?
Switch pro-con gyro to PS4 gyro
At the moment, there is no Gyro on our virtual controller, but we are planning to do it in one of the next versions.
In the meantime, I think we may find some workaround. What does Gyro do in a game? Is it used for moving a camera? Usually, you can do the same with a Stick, so you can choose Gyro on your controller and map it to Stick. Could you please try it?
Thank you for your reply.
I see, as I mentioned above virtual ds4 has no gyro or acc axis implemented at the moment. So it not possible to do gyro adjustments with virtual DS4 using rpcs3 utility.
What I'm asking for is to set gyro to Stick and try ingame without additional remapping in rpcs3 utility. So if the stick is used in the game you may run or camera moves you may use gyro that emulates stick.Don't worry! Be Happy!
Is there anything new on the subject so far? I am in the same situation, one PS3 game requires Sixaxis in order to work and RPCS3 still does not have motion controls emulation. The best luck I've had so far is with DS4Windows, where the virtual ds4 would cause constant motion downward, but unable to control it.
The latest 5.6.1 allows remapping your Switch Pro (Joy-Cons) controller to virtual DS4 and get the native Gyroscope (screenshot). Please, update your current version to the new one.Don't worry! Be Happy!
Alright, so when I actually know what I'm doing, it works perfectly. It even works using a third party $30 switch controller, which I was surprised to find out has a gyroscope.
Now this might deviate from the subject a bit. Is it possible to use a keyboard, a X360 controller, or whichever Non-gyro device to output gyro values? As in: is it possible to fully emulate a gyroscope?
I use a X Series controller as my main, and it obviously doesn't have a gyro. I do alot of emulation, and altho I could use my old controller when games need gyro, I'd like to be able to map gyro values to, say, the right joystick or something.
Hi there,
You can't. This is an option of emulating gyro for physical controllers that has gyro. For, example, you have a Switch controller that has a gyro, but you can't use the gyro in the game because the controller is not supported. So, you remapped Switch Pro to virtual DS4. A game sees a DS4 including gyro.
No option to remap control to gyro move(s).Don't worry! Be Happy!
