The press time to perform the activators are too slow, and I always forgo using them because there's no point if I can't switch my weapons quickly (i.e. DOOM 2016, DOOM Eternal). By default:
Is there any way to have these press times less than the minimum, or at least have the Double Press time less than 50ms?
- Long Press is minimum 100ms
- Double Press 50ms
- Triple Press 150ms
- Shortcut 50ms, and
- Slot Hotkey 50m
According to our internal testing, in order to press a button (pretty quickly), a person needs about 20-25 ms. That is why the minimal Double Press time is set to 50 ms, because if it is less, it would be pretty challenging to get Double Press mapping. But if you are ready for this challenge, we take your suggestion into account and will try to reduce the minimal press time for this activator type.
